vcRoutine
Routine contains a collection of statements that can be executed by the executor.
Module: vcExecutor
Parent: vcScope
Children: vcProcessRequirements, vcProcessRoutine
Referenced by: vcCallRoutineStatement.CallRoutine, vcProcessExecutor.Processes, vcProgram.MainRoutine, vcProgram.Routines, ... (see more)
vcProgram.Routines
vcProgram.createRoutine()
vcProgram.findRoutine()
vcStatement.ParentRoutine
vcStatementHelper.GetActiveRoutine()
ExecutorvcBehaviorRGets the executor associated with the routine.
IsPersistentBooleanRWGets or sets the value which defines if the routine is saved with the executor.
NameStringRWGets or sets routine name.
ValueError: When given name is empty or not unique.
PropertiesvcPropertyContainerRGets the properties of this routine.
deleteNoneNoneDeletes the routine.
RuntimeError: When trying to delete a requirements routine.
Example: Access Process Statements
"""Read the process statements of a routine in Process Editor found via process executor behavior."""
import vcCore as vc
comp = vc.getComponent()
exec = comp.findBehavior("ProcessExecutor") # vcProcessExecutor
routine = exec.Processes[0] # vcRoutine that inherits from vcScope
print (routine.Statements) # access the statements of the routine
Example: Create New Process Statement
""" Creates a new process statement and sets the property values."""
import vcCore as vc
import vcExecutor as vc_ex
new_statement = routine.createStatement(vc_ex.vcStatementType.PROCESS_SET_PROPERTY) # createStatement from vcScope
new_statement.TargetProperty = "x"
new_statement.ValueExpression.Value = "y" # set the value of vcExpressionProperty
Example: Delete Process Statement
""" Deletes a process statement."""
import vcCore as vc
statement = routine.Statements[0] # take the first statement of the routine
statement.delete()
